DRL LED Bulbs
DRL LED Bulbs
  • Click to enlarge
5.0 average, based on 5 reviews
£23.00
Product Information
Specification
LED bulbs to replace the Tungsten DRL bulbs in the 2018+ Jimny (JB74W).
These are simple plug in replacements.
The new Jimny has a CAN-BUS digital system with a BCU (Body Control Unit) monitoring the bulbs. Therefore LED replacements have to be compatible with the BCU, this means they have to have the correct resistors fitted in the bulb unit. These have the correct resistors, other LED bulbs of similar fitment may not work correctly. In addition these have been tested in a UK Spec SZ5 Jimny, other national specifications may differ.
Supplied as a PAIR.
The video on how to fit them is here
Note:
1. The DRL Leds have an O-ring to seal them into the fitment to prevent water ingress. This O-ring can make them difficult to insert into position. Lubricating the seal with silicon grease or other light lubricant will make the fitting a lot easier.
2. These are for a Jimny that ALREADY has DRL lights fitted, these are an LED upgrade. They CANNOT be used to add DRLs to a car that does not have the wiring or correct lamp housing.
3. Some countries have different set up (El Salvador and possibly other Latin American countries for example). Make sure they are compatible with your Jimny. Contact me if in doubt.
4. Before calling me to say they are different from your bulbs check that you have not removed the fog light bulb by mistake! smiley
Product CodeDRLLED
ManufacturerBigJimny
ConditionNew
Weight0.101Kg
Customer Reviews
Average Rating: 5
Jimny DRL led Bulbs
12345
The bulbs were a bit fiddly to install - but very worthwhile doing as the results are great! - much better than the - very dim - original ones!! (Dec 09 2020, 17:47 PM)
Highly Recommend
12345
They are really easy to install and look fantastic! (Jun 12 2020, 11:26 AM)
Perfect
12345
Easy to install and looks very nice (Mar 21 2020, 20:39 PM)
DRL Led bulbs.
12345
Delivered quickly. Looks fabulous, thank you Martin for offering a great service. (Mar 21 2020, 06:53 AM)
LED DRLS upgrade Jimny 2019 SZ5
12345
Great product and invaluable installation video. Delighted. (Dec 18 2019, 15:44 PM)
Write a review
Write Review
Top
eCommerce by CubeCart
