Front Shock Bolt
Front Shock Bolt
  • Click to enlarge
Product Information
Specification
When you remove your Front Shocks then the inevitable will happen. You will find one of the bolts has siezed or cold welded itself into the Bush.
You WILL end up cutting one off. Therefore make sure you have the correct parts to hand when you start.
This set consists of a High Tensile Bolt (M12 x 60mm METRIC FINE) and a Nyloc nut
Just by buying these should ensure that yours undo without any problems!
This set will do ONE Front Shock Absorber.
Product CodeM12x70-1xNUT
ManufacturerBigJimny
ConditionNew
Weight0.05Kg
Customer Reviews
Write a review
Write Review
Top
eCommerce by CubeCart
