BigJimmy Store uses cookies. For more detailed information about these cookies please see our privacy policy. Please accept to continue or block all non-essential cookies.
£0.00
Your Basket
Your basket is empty.
Added to Basket
db3f641d0b0f2eaacb48b6649609ee6f
£ GBP
Login
Register
Advanced Search
Please enter a search keyword
Advanced Search
Shop by Category
Shop by Category
Jimny - Gen3
Jimny - Gen3
Parts & Service
Parts & Service
Bearings and Seals
Filters and Cooling
Engine Parts
Engine Parts
Engine Parts
Sensors
Belts
Braking/Clutch parts
Steering, Axles & Bushes
Electrical
Body panels and parts
Nuts, Bolts and Fittings
Suspension
Hardware
Modification Parts
Accessories
Promotional
Jimny - Gen4
Jimny - Gen4
Parts & Service
Parts & Service
Brakes & Clutch Parts
Bearings and Seals
Filters and Cooling
Accessories - 2019+
Suspension
Modification parts
Other Suzuki Models
Back
Home
Jimny - Gen4
JavaScript is required by this website. Please enable this in your browser settings.
Jimny - Gen4
Parts for the Generation 4 Jimny - 2019 onwards
Parts & Service
Accessories - 2019+
Suspension
Modification parts
Sort by
-- Please Select --
Name (Z-A)
Name (A-Z)
Date Added (Newest First)
Date Added (Oldest First)
Price (High-Low)
Price (Low-High)
Hub Nut Tool
This is the special tool required to undo the front hub nut when changing the Front Wheel Bearing or performing other ma…
£33.74
Hub Nut Tool
£33.74
Rear Speaker Mounting Kit
This is the kit required to mount rear speakers in a 2019 model Jimny. The UK specification jimny does not come with rea…
£62.72
Add to Basket
£62.72
Add to Basket
Trailmaster 50mm (2") Lift Kit - 2019
This is the lift kit for the Generation 4 Jimny. Many people have reported over the years on how good the other kits in…
£712.00
Trailmaster 50mm (2") Lift…
£712.00
Front Speaker Mounting Upgrade Kit
This is the kit required to mount larger front speakers in a 2019 model Jimny. The UK specification jimny with 10cm rea…
£27.14
£27.14
Armrests (Storage)
VEHICLE FIT The standard item offered here FITS A UK GENERATION 4 JIMNY out of the box and …
£120.00
Armrests (Storage)
£120.00
Differential Filler Plug
This is the front and rear differential filler plug for a Suzuki Jimny. Fits all Jimny models. Please note the sea…
£6.55
Add to Basket
£6.55
Add to Basket
DRL LED Bulbs
LED bulbs to replace the Tungsten DRL bulbs in the 2018+ Jimny (JB74W). These are simple plug in replacements. The…
£23.00
Add to Basket
DRL LED Bulbs
£23.00
Add to Basket
Roof Trim Kit
This is the black edging trim for the Roof gutter of the 2019+ (Generation 4) Jimny. In the UK, some of the colour op…
£197.12
Add to Basket
Roof Trim Kit
£197.12
Add to Basket
Rear View Camera Kit
Genuine Suzuki Rear View Camera kit. This kit includes the rear view camera, installation harness and manual This …
£274.40
Add to Basket
£274.40
Add to Basket
Differential Filler Gasket
The gasket (or washer/oil seal) that seals the Differential FILLER plug on Gen3 (JB33/JB43) Jimnys and Gen4 Jimny (JB64…
£2.55
£2.55
Heated Door Mirror
Genuine Wing HEATED Wing mirror for the JB74 (2019) Jimny. These are fitted as standard on the UK SZ5 specification …
£170.00
Add to Basket
Heated Door Mirror
£170.00
Add to Basket
Sill Covers/Garnish
Genuine Suzuki Sill Covers/Garnish These are stylish metallic look sill covers that fit over the standard sills. S…
£504.00
Add to Basket
Sill Covers/Garnish
£504.00
Add to Basket
Armrest adaptor - EU Jimny - Gen 4
VEHICLE FIT This is the substitute adaptor to fit the armrest to a Left Hand Drive (LHD - e…
£0.00
Add to Basket
£0.00
Add to Basket
Brake disc (VENTED) - Suzuki Jimny (108.3mm)
Vented brake disc Note: discs come with two separate centre hole sizes, please ensure you order the correct one. T…
£27.00
Add to Basket
Brake disc (VENTED) - Suzuki…
£27.00
Add to Basket
Breather Valve Kit
Genuine Suzuki breather valve kit This is the pop-up valve on top of the differential. Perhaps you have damaged yours…
£8.00
Add to Basket
Breather Valve Kit
£8.00
Add to Basket
Caliper - VENTED DISK
This is the lengthed Caliper that is required for vented disk installations It is a fully commercially refurbished ca…
£100.00
£100.00
Caliper Carrier - VENTED DISK
This is a Caliper Carrier that is required to fit vented disks to both Gen3 (Early and Late) and Gen4 Jimnys. This …
£30.00
£30.00
Dashboard panel
Driver side (UK) lower dashboard panel (Please enquire about overseas, ie Left hand drive versions) This is the panel…
£23.30
Add to Basket
Dashboard panel
£23.30
Add to Basket
Front Brake Pads - VENTED
Brake pads for vented disk/caliper conversion. Note: THESE ARE NOT FOR STANDARD JIMNY BRAKES Comes as a full front…
£35.00
Add to Basket
£35.00
Add to Basket
Differential Drain Gasket
The gasket (or washer/oil seal) that seals the Differential DRAIN plug on Gen4 (JB74) Jimnys. Notes: This gask…
£1.99
Add to Basket
£1.99
Add to Basket
Sunvisor
Upgrade your SZ4 Jimny with these sunvisors with the built in mirror and licence holder. The SZ4 and SZ4 Commercial h…
£53.21
Add to Basket
Sunvisor
£53.21
Add to Basket
Caliper Fitting Kit (VENTED DISK)
Kit containing caliper fittings for the vented disk caliper on a Suzuki Jimny. Note that this does not fit standard UK …
£13.00
Add to Basket
£13.00
Add to Basket
Aircon/Pollen Filter
Standard pollen filter for Gen4 Jimny This is a genuine filter, it is the one that goes behind the glovebox.
£19.19
Add to Basket
£19.19
Add to Basket
Air Filter - Genuine Suzuki (Gen4)
A genuine SUZUKI replacement top quality Air Filter. For K15 Gen4 Jimnys only Note: Picture does not show exac…
£29.80
Add to Basket
£29.80
Add to Basket
Aircon/Pollen Filter (Anti-allergen)
Upgraded anti-allergen filter for Gen4 Jimny, this is a Suzuki Accessory This is a genuine filter, it is the one tha…
£25.14
Add to Basket
£25.14
Add to Basket
Crankshaft Woodruff Key
Woodruff key used on both G13, M13 engines including VVT and K15 (Petrol - Gen4)
£3.46
Add to Basket
£3.46
Add to Basket
Brake Banjo Bolts
Pair of Banjo bolts complete with a pair of copper crush washers Essential when working on the calipers to get a good…
£3.50
Add to Basket
Brake Banjo Bolts
£3.50
Add to Basket
178
Featured Product
Tie Rod Ends - Suzuki Jimny (RH)
£11.63
Best Sellers
Kingpin Bearing Kit (Premium - Koyo)
£24.50
KingPin Shim Kit
£3.50
Hub Nut Tool
£33.74
Swivel/Knuckle Seal
£30.24
Suzuki Jimny Wobble Kit
£87.36
Waterproof Grease
£10.00
Kingpin Bearing with Swivel Seal Kit (Premium - Koyo)
£48.00
Loctite Premium Copper/Silicone Sealant
£9.50
Front Axle Oil Seal
£3.00
Rear Wheel Bearing Kit (ABS)
£74.00
Top
eCommerce by
CubeCart
