Universal Joint - GREASABLE
  • Click to enlarge
  • Click to enlarge
  • Click to enlarge
  • Click to enlarge
£14.00
Product Information
Specification
Replacement Universal Joint for the Jimny. NOW UPGRADED BY MANUFACTURER TO BE GREASABLE.
This the proper one listed for Jimny Front and Rear Propshafts and comes complete with replacement C-Clips. This is a now a greasable UJ as the manufacturer has recently changed the specification.
Also note: Older Jimnys are described by the Suzuki as having non-replaceable UJs, they quote you for the whole propshaft. I understand you can actually change them
I have fitted these exact UJs to my Jimny and have noted the following:
1. The introduction of the grease nipple can mean that the new C-Clip (supplied) does not fit easily, I re-used one of the original style clips which fitted fine - the pictures show the different C-Clips
2. The grease nipple is not ideally positioned as it seems that grease comes out of the seal on the local cup rather than feeding through to the other cups, however as the other cups are supplied packed with grease it might be that the grease has nowhere to go at this first fill.
Product CodeADK83901
ManufacturerADL/Blueprint
ConditionNew
Weight0.45Kg
Customer Reviews
Write a review
Write Review
Top
eCommerce by CubeCart
